  #1
Old October 13th, 2003, 02:50 PM
DavidRT2T DavidRT2T is offline
Default Spark plug and Gap 1994 Evinrude 175
I have a 1994 Evinrude 175 Intruder. It is currently running NGK BR9HS-10 plugs and the NGK Book calls for BPZ8HS-10 which I understand to be an inductive Resistor plug made for CDI ignitions. My first question is is this the correct plug (the BPZ8HS-10) and why would the other plug ever be used if it wasnt correct? Question 2 is the NGK book and website say the Gap should be .030 but the plug comes pre-gapped at .040......which is correct?
  #2
Old October 13th, 2003, 03:00 PM
Paul Moir Paul Moir is offline
Default Re: Spark plug and Gap 1994 Evinrude 175
According to boatsetup, the correct plug is a Champion QL78YC, gapped at .030. Johnson/Evinrude engines and NGK sparkplugs do not get along well for some reason.PS - the BPZ plug has a choke (inductor) in it rather than a carbon resistor, like the BR plug. A choke is appropriate for a CDI ignition since it suppresses ringing. I expect the reason you had BR plugs in it is that they're cheaper than BPZ. I don't know why they felt they needed a colder plug (the 9 instead of 8).Good luck!
  #3
Old October 13th, 2003, 05:44 PM
Paul, Thanks for the info. What you tell me jives with what NGK told me. The boat has been running Great on the NGK so I will stick with them even though they are VERY expensive. I just noticed the manual says Champion QL77JC4.....why so many different plug options?
  #4
Old October 13th, 2003, 06:08 PM
bradley1393 bradley1393 is offline
The ql plugs are the correct ones. Not often will you get me to put anything but ngk in an outboard.... but the omc are very finicky about their plugs. If you have any idle or stumbling problems you might want to switch to the champions. By the way the -10 on your ngk plug is actually a preset gap of 1.0 mm -8 = .8 mm etc.
  #5
Old October 13th, 2003, 07:27 PM
I think there was an updated recommendation on that engine. Anyway, they're not that much difference between a QL78YC and a QL77JC4: Q is for the inductive resistor.L is the length of the threaded part of the plug (.472")77 or 78 is the heat range. Too cold and the plug will foul, too hot and it's a site for pre-ignition (bad). For champion plugs, heat range goes up with number. NGK goes down. Heat range is specific to an engine. There's very little difference between 77 and 78.Y has a protruding ground, J has a cutback electrode.C indicates a round ground electrode with a sawed gap.4 is the production gap (0.044").NGK uses a different nomenclature, but it works a lot the same way.Like Bradley, I have no warm spot in my heart for Champion plugs, but they do work better in OMC outboards. Oh, and I think you'll find they're a lot cheaper than the proper NGK plugs.Hope this helps!
  #6
Old October 13th, 2003, 07:35 PM
DJ DJ is offline
David,LOSE the NGK's. As said, OMC's don't like them. I'm no fan of Champ's but the the OMC engines run better on them.
  #7
Old October 13th, 2003, 08:51 PM
WOW, I guess I should think about the champion plugs. I went to sparkplugs.com and used the champion plug finder and it says to use the champion marine 5939 plug????? Its description sounds similar to the NGK plug and it is also VERY PRICEY. I am so confused. Is the gap .030 correct no matter what plug and what factory plug preset gap is???? Thanks again.
  #8
Old October 13th, 2003, 10:21 PM
The 5939 plug is very nice. I'm sure the stainless steel jacket will still look all shiney a year from now when you throw the sparkplug in the garbage while your doing your routine maintaince. Get the equivalant mild steel jacketed QL78YC and pocket the difference. I guarantee your garbage can won't know the difference. Gap it to 0.030 no matter what the factory builds the spark plug at. That's just a conveniance for people who don't know how to do it in NGK's case. In Champion's it seems to just be a coincedance they like to report. The size of the gap is mostly governed by the ignition system and RPM operating range of an engine, so follow the engine's manufacturers recomendation.Hope this helps.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Which spark plug for a Evinrude 150?? Swerve-N-Protect Johnson & Evinrude Outboards 14 November 6th, 2005 02:08 PM
evinrude 175 hp intruder modell 1994 no spark piranha Johnson & Evinrude Outboards 0 June 20th, 2004 01:27 AM
Spark plug for a 63 Evinrude Ragtime Johnson & Evinrude Outboards 4 July 11th, 2003 06:26 AM
82' Evinrude 70 hp Spark plug Deuce22 Johnson & Evinrude Outboards 0 July 16th, 2002 02:52 PM
Spark Plug Gap (.030 VS .040) Evinrude rickdb1boat Johnson & Evinrude Outboards 4 July 8th, 2002 05:50 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
