I just purchased aboat with a 90 Johnson GT 150 VRO that is getting no fire to any plug. I have a manual for the engine and i tested the stator to find that 1 of the 3 packs is bad but i was told by a boat mech that this should not cause a no fire situation. I disconnected the harness from the boat, used a starter button on the test assembly that i borrowed from a friend and had no fire that way so i have ruled out the wiring in the boat(kill switch,ignition).the oil injection on this motor has been disconnected. Im at a loss. Any help will be appreciated. Thanks
