Re: 1978 evinrude 55hp stalling
There are several items that could cause high end performance issue.Insure that the fuel filter is clear, the fuel tank is venting freely and the fuel tank pickup tube is clear and unobstructed.You could try pumping the fuel primer bulb when engine begins to fall at higher speeds and see if it enables the engine to pickup.If so ,would be indicative of failing fuel pump.You could also have fouled carburetors limiting the fuel flow.If all of these check out your next culprit could be a timing or ignition problem.
