40 hp evinrude lark 4
critter34
1962 40 evinrude lark runs great until throttle up doesnt seem to have rpm until i open front cover on motor,then it runs high rpm anybody recognize this problem?
Joe Reeves
Re: 40 hp evinrude lark 4
Critter.... The engine is breathing its own exhaust fumes. Check the large rubber exhaust relief tube just under and at the rear of the powerhead to be sure that it is not cracked, and also that it is seated correctly.<br /><br />Half way down the exhaust housing (hsg between the powerhead and the lower unit), you'll see a oblong plate attached with two screws. UNder that plate, you'll see another "inner" plate. If that inner plate is loose, or if the gasket is missing, exhaust fumes will be forced out there, up, and into the air intake of the carburetor.
critter34
thanks Joe i will check that, its funny because my 9.5 does the same thing
