Re: Install electric fuel pump on 57 Johnson?
I had the same idea. I have a 1978 85hp Evinrude and a 9.9hp Johnson trolling motor. I guess I'm lazy, but I got tired of having to walk back and squeeze the priming ball. Especially for the Evinrude in cold weather if it hadn't been run for several weeks.<br /><br />Here's what I did:<br /><br />I installed a Stewart-Warner 12-volt electric pump which delivers 5 psi. I mounted it in an open ventilated area in the back of the boat. However, I wired it to a spring loaded switch on the console so I could use it only as a boost-pump (or priming pump) prior to starting.<br /><br />The pump doesn't run during engine operation yet fuel will still flow through the pump.<br /><br />Here's another advantage. When Winter comes and I want to empty any remaining fuel, I connect a long fuel hose to the discharge side of the pump and pump the fuel into my vehicle! That way I start with a fresh empty fuel tank in the boat for next season.
