  #1
Old October 9th, 2003, 01:39 PM
scampbell scampbell is offline
Default '84 Evinrude 150 Won't Crank
I recently bought an '84 Wellcraft Fisherman C/C boat with an Evinrude 150 on it. Boat ran good the 1st 3 times that I took it out. On my last trip out (when it actually cranked), I noticed it running rough idling into the harbor, and it finally died when I reached the dock. Next time out, it would only crank if I gave it full choke, & had throttle nearly wide open, but died when I pulled off of the throttle. I tried changing out the plugs, but that didn't work. I thought it wasn't getting gas, but seemed to be getting plenty. Any common problems with this year/type of motor? I am new to the outboard scene, and would appreciate any advice.
  #2
Old October 9th, 2003, 02:05 PM
Hooty Hooty is offline
Default Re: '84 Evinrude 150 Won't Crank
Howdy Mr. Campbell and welcome to iboats. The fact that you had to use the choke and full throttle makes me think your problem is fuel related. Get yo'self a spray bottle and put some premix fuel in it. While cranking the engine, give the carbs a couple of shots of fuel and see if it starts or even tries to start. If it does, which I think it will, check fuel pumps and maybe do a carb overhaul. If that doesn't work, get back to us on this same post so's we can keep up with whats been done already.G'luck & c/6Hooty
  #3
Old October 9th, 2003, 02:20 PM
Thank you for your help. I'll give this a try this weekend and let you know how it goes. The only reason that it may not be fuel related is that the plugs were wet when I took them out.
  #4
Old October 9th, 2003, 02:29 PM
BTW...where would be a good source to buy carb. kits and plug wires and such???
  #5
Old October 9th, 2003, 02:40 PM
NAPA will have or can get the carb kits. As far as sparkplug wires, any will work just so they're solid core wires, not carbon fiber.c/6Hooty
  #6
Old October 9th, 2003, 03:04 PM
Thanks again.
  #7
Old October 9th, 2003, 03:18 PM
ezeke ezeke is offline
HiYou can save a lot of Q&A if you get a new portable tank with new fuel line, fill it with fresh premix and see if anything changes. That will get you up to the fuel pump. Next:If the fuel pump is the problem, you can check by raising the tank to the level of the powerhead, and having someone keep steady pressure on the bulb while you stay at the control.NextYou need a fully charged, powerful battery to properly start your motor. The cables need to be in good condition and tight. Loose or corroded cables and/or a bad battery can cause permanent damage to electrical components.Hope this helps.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Evinrude crank shaft ??? sportcraft17 Johnson & Evinrude Outboards 4 July 10th, 2006 10:21 PM
'89 Evinrude Won't Crank Crash0016 Johnson & Evinrude Outboards 9 May 19th, 2006 04:05 AM
evinrude 40 HP crank from '74 '75 or 76 eenhorn Johnson & Evinrude Outboards 7 May 4th, 2005 11:48 PM
evinrude 40 HP crank from '74 '75 or 76 eenhorn Boat Restoration and Building 2 May 2nd, 2005 10:26 AM
115 Evinrude crank interchange? drackley Johnson & Evinrude Outboards 4 February 10th, 2003 02:51 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
