I am grateful for any help on this. I have a 79 model 115 hp V4. The problem is this motor has set for 2 yrs. I am trying to get it back on the lake. This thing runs great when the muffs are hooked up and when throttled it sounds great and smooth. While running I will pull each plug wire individually and it will cause the motor to spit and sputter until the wire is connected again. This happens on every cylinder but 1. On one cylinder it does not make any difference whether the wire is hooked up or not. I have checked the spark and it is fine. Plug is fine, 115 psi compression. Carbs have been built.<br />I put this motor on a 18" procraft bass boat but could not get the boat over 18 to 20 mph.It has 13x19 prop. Please advise. Thanks in advance.
