Ever since I bought this thing I've had a problem at WOT. After about 5 minutes it immediately cuts from 5200 RPM to 4700 RPM and won't run higher for the rest of the day, except for occasional bursts up to 5200 RPM.<br /><br />I thought it was a fuel problem at first and completely reworked the fuel system all the way from gas pickup to carbs. It runs a little smoother now but still has the problem at WOT.<br /><br />I am convinced it is the ignition system. A weird thing happened the last two times I was out. The tach sputtered and then quit. It will occasionally come back on, but it is really sporadic.<br /><br />One thing I did on the engine --- I rerouted the charging harness (back to the correct way). This required unscrewing the terminal strip. Well, my idiot self didn't disconnect the battery. At least one wire, from the engine harness, sparked on the block. I guessed that since ignition was off, it was a wire straight from the battery and wouldn't cause a problem. Am I right?<br /><br />Anyway, with the problems in both the tach circuit and in the ignition, I am thinking the stator is going bad. Does this sound right? Does it sound like I burned up the rectifier also? Could it be the power pack?<br /><br />I am going to do some resistance checks on the rectifier tomorrow. Does anyone have any other electrical tests, with the boat out of water, that they recommened? Anything I should know?<br /><br />Thanks in advance!
