  #1
Old September 27th, 2003, 04:06 PM
Sal G Sal G is offline
Default Small chunk of aluminum missing around water jacket- will this effect my rebuild
A mechanic is breaking down my engine (85 140 VRO)for a rebuild. Tnere is 1 small chunk (and several minute fragments) of metal missing on top side of the water jacket facing the cylinder side but not touching the cylinder sleeve.Is this caused by the aluminum becoming porous? Is this one of the reasons why a former mechanic refused to work on a looper- but only a crossflow.(he did mention that these engines had a tendecy for the aluminum to become porous after a period of time) This new mechanic said this may be a problem when they plane the head to make it level. Is it possible to patch the area before the plane it? Needless to say, the mechanic made it clear that the ports must be inspected and x-rayed by the machine shop to see if the engine is salvageable. I'm hoping I made the correct decision to rebuild this engine. Do I need to be so concerned?
  #2
Old September 27th, 2003, 04:31 PM
alcan alcan is offline
Default Re: Small chunk of aluminum missing around water jacket- will this effect my reb
Hi SalYes indeed, you should be concerned. I am currently haveing the same type problem with a 1990 40hp evin. the machinest that I've been talking with says he may be able to remove the sleeve and weld up the cracks. Reinstall a sleeve and deck the block. None of this has taken place yet. So we will see. I have run into this problem before, with older engines. I just scraped them for parts, as any machine work of that nature would far excede the value of the unit. If this problem can't be corrected it will only worsen to the point of uselessness.
  #3
Old September 27th, 2003, 04:39 PM
Solittle Solittle is offline
Dressing the head should have nothing to do with the water jacket in the block. It would be difficult to comment on what impact the missing chunk could have on the rebuild from here - even with a picture. I would take the block to the machine shop myself and talk to them directly on whether your motor is rebuildable. Do that before you let your mechanic do any work on it. Remember that your mechanic gets paid for what he does even if he is working on a block that can not reasonably be rebuilt.I have a block in my garage the same way.
  #4
Old September 27th, 2003, 05:08 PM
Joe Reeves's Avatar
Joe Reeves Joe Reeves is offline
Sal..... It's a matter to be concerned about but the problem is easy to cure.I've encountered many blocks that were affected in that manner, usually loopers for some reason. A reliable machine shop that is experienced in Heli Arc work (Aluminum welding) can build up and replace the missing aluminum, then refinish the surface to it's original height (no milling down). The only way to go.I have my machine work performed by Precision Mfg & Sales, located in Clearwater, Florida. I have yet to encounter a problem with their workmanship.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Long term effect of water in oil dcook214 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 6 May 24th, 2006 02:35 PM
salt water effect on aluminum boat elwood22165 Boat Topics and Questions (not engine topics) 2 November 28th, 2005 06:28 AM
Small aluminum dingy amirm Boat Topics and Questions (not engine topics) 5 July 12th, 2005 03:09 PM
Missing small part mkaminski Johnson & Evinrude Outboards 8 April 22nd, 2005 01:17 PM
Where to look for small aluminum boat? fireship1 Dockside Chat 2 April 26th, 2004 04:47 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
