Re: 70 hp Johnson Stalling
I had the boat out for 3 hours trolling with trolling plate. It stalled a couple of time while trolling but I tilted the motor up and it ran fine. Docked the boat after 3 hours of running let it sit for 1/2 hour and went to start it up. It started fine but when put into gear it stalled, restarted it and it became more difficult to start and again it stalled when put into gear. Got it back to the dock checked plugs , they were not very snug and I also checked the gap (30). I changed plugs and also the fuel filter was changd because of sand found in the filter. Started it back up but again once in gear it stalled, restarted and it then ran better. Runs well at high speed, took it out the next day and trolled again for 3 hours but did not use the trolling plate ,it ran well got back to the dock it sat for 45 min and when I restarted it it stalled again when put into gear.<br />It is a 1997 70 hp Johnson long shaft
