  #1
Old September 25th, 2003, 12:01 AM
ruddy ruddy is offline
Default 74 Evinrude 70HP won't run in forward gear
My motor will start and fast idle OK. If I'm quick enough on a shift into reverse (idle speed seems too low), it will run great. However, shifting into forward causes it to struggle like it's starving for fuel and die.Where should I start to sort this out?Thanks.
  #2
Old September 25th, 2003, 12:19 PM
Chinewalker's Avatar
Chinewalker Chinewalker is offline
Default Re: 74 Evinrude 70HP won't run in forward gear
Hi Ruddy, First, don't run it anymore until you've sorted it out. Check for spark in all three cylinders. If that's good, move onto a compression check. You want them all relatively even in the 120+ neighborhood (my '80 is 155 psi across the board). If it passes step 2, move onto the fuel system. Remove and disassemble all three carbs and clean them internally. Compressed air and carb cleaner a-plenty. Do get a manual to do this part - whether you buy one (here at iboats) of borrow one (library, etc.). My gut feeling is you've got a fouled carb. Simply spraying carb cleaner down the carb will NOT fix your problem...- Scott
__________________
Share A Project Page for 1971 GW Invader Banchie 13
http://www.shareaproject.com/pages/p...,p,433,00.html
Share A Project Page for 1976 American 18
http://www.shareaproject.com/pages/p...,p,404,00.html
Share A Project Page for 1974 American 15
http://www.shareaproject.com/pages/p...,p,405,00.html
  #3
Old September 25th, 2003, 01:19 PM
Thanks for the reply, Scott. I just replaced the PowerPack and spark plugs, and I verified I was getting a good spark on all three when I did. It ran OK hooked up to a hose, so it seems to have trouble with a real load on the prop. I'll check the compression next and go from there.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
77 johnson 70hp stuck in forward gear johnsorude 70 Johnson & Evinrude Outboards 2 August 17th, 2006 07:30 PM
35 hp 84 Evinrude jumps out of forward gear Johntree Johnson & Evinrude Outboards 3 April 6th, 2006 05:03 PM
35 hp 84 Evinrude jumps out of forward gear Johntree Non-Repair Outboard Discussions 1 April 6th, 2006 03:40 PM
87 175 V6 evinrude - not going into forward gear jacob_smith14 Johnson & Evinrude Outboards 1 June 16th, 2004 04:33 PM
'68 Evinrude 18 hp forward gear slipage bassscout Johnson & Evinrude Outboards 4 May 31st, 2002 08:48 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
