I have a 97 Johnson 115hp which I bought used 4 months ago. The engine has been running great except it was a little rough when idling. My last trip out a constant knocking sound started coming from the engine (sounded like it was coming from around the flywheel). The engine sounded find when I first cranked it but when I started it up after my 2nd or 3rd stop of the day I noticed the knocking sound, no warning lights came on. It knocks when idling and when running full throttle. I took the cover off and didn't notice anything out of the ordinary but then again I'm no mechanic. I have a seperate oil tank so I don't have to do the gas\oil mixture, I assume the ratio is good but is there a way for me to check it? I don't think this is the problem because neither of my oil warning lights came on. Is there anything I should be looking for that may be causing this. I was getting ready to take it in for service because of the rough idle and my rpm gauge not working then this problem showed up. Any suggestion as to what it might be so don't get burned at the repair shop? Any tests I can do prior to taking it in? I'm worried I might be getting ready to throw a rod or something.....Could this be a symptom of a rod getting ready to go? Thanks in advance.....
