Seahorse outboard year????
bobbyhoth
The model number is JW-10, the serial number is 1183521. Also, what is the fuel mix ratio? And just one more, it runs very well, but where does the water "pee" out??<br /><br />Thanks in advance.<br /><br />Bobby Hoth
Xcusme
Re: Seahorse outboard year????
What you have there is a 1952->1954 3HP Jonny'.
bobbyhoth
Thanks, what about the water peeing out?? seemed to run kinda "hot"? and what should I mix the gas at???? Don't want to ruin this oldie. Thanks
Paul Moir
Water comes out as a mist from the 6 small holes in the front of the leg, just below the transom bracket, I belive. There is no tell tale as such, these are simply the idle exhaust relife, and it carries some of the cooling water. There may be a flush screw at the base of the tiller arm you can check from. The flush is on the cold side of the cooling circuit, so don't run it without the screw for more than a couple seconds.<br />If it's too hot to hold your hand on for five seconds on the top of the head, it's probably overheating. <br />Mixture is 24:1.
bobbyhoth
Thanks for the info, yup, its overheating. I can't even begin to get my hand close to the heads. Are these motors worth anything? I paid $30 for it at a garage sale. Didn't know what it was, but it ran and was old. LOL
