Re: Fuel mix 50:1 Why still smoking???
Haven't checked that yet. Going to work on it today. I'm taking Sea Foam Deep Creep, carb cleaner, and some Iso Heet. My father in-law says that he changed the gas and cleaned the tank out really well, but can't be sure it was cleaned as well as I would have done it, and I cleaned the line. Will add a small amount of heet while I tear the carb(s) down and clean those with the carb cleaner. While I'm doing that, I will fill the cyls with Sea Foam, as well as the case when the carbs are removed. Assemble and then run the rest of the can of sea foam through with the fuel. Should clean it up really good. I'll check the compression after this has been done. Also will up the ratio to 75:1 for 2 gallons, then back to 50<br />Good Plan? Any suggestions?
