1st time posting, please excuse any improper prcdrs. <br /><br />I just bought an old Lucraft w/ 1976 or 77 55 hp Evnrude. It has a few problems I have solved with manual, however, cant put my hands on the manual today while working on removing steering cable. I removed the steering wheel and began pulling the threaded shaft out... (I figured to take entire cable to shop and have new one made up.) <br /><br />Well, there is not enough room to remove entire shaft? Should I just cut the cable then remove? If so, how to get newly made up on in without same problem? Or does the cable connect some other way which is easier to remove? <br /><br />Hope this isn't an incorrect place to post. Any help will be greatly appreciated.
