PULL CORD BROKE
EJGANGSTAD
I recently purchased my first outboard motor (older 20hp johnson). The pull cord broke just below the handle. I've had chainsaws uncoil on me before and I am wondering if this is something i can do myself, or if I should take it to some one?
hondon
Re: PULL CORD BROKE
Do,nt try this without some guidance.That spring is alot bigger and just waiting to get you.This can be a frustrating repair so if you chose to farm it out do not be surprised to get a bid of a couple hours.If you do it yourself you'll see why.
rolmops
Re: PULL CORD BROKE
Hello.<br />If this engine is from between '66 and '70 you need a 75 3/4 inch starter rope safety glasses some simple tools (Vise grip)and most definitely a manual that does not just give specifications ,but explains how to do it.<br />I like seloc because it takes you by the hand and gets you to where you can safely do it yourself.<br />good luck.
EJGANGSTAD
Re: PULL CORD BROKE
Thanks guy's! I am very inexperienced but i think i will try it(maybe I am to cheap).
Captain Frog
Re: PULL CORD BROKE
EJ, Have a 75 Johnson 15 that broke the rope inside and along with the help of a clymers manual I managed to fix it in about 2 hrs. Just use some common sense and a manual. Good luck.
