My project boat just came from its first trip to the water. Started just fine put it in reverse, backed out in forward ok ran a little rough but its the first time its been run in months. Drove slow at first and came up on the throttle slow till it was on plane. About 10 minuits later slowed and tried to put it back in neutral. Wonld not go to nutral, steared for the dock and turned the motor off. Went into neutrel just fine once the engine stoped. Started it up again and it went to almost 4000 rpms. I have no idea why??????<br /> Is their a set screw that I can adjust?<br /> Why would it start just fine and idle low then stay so high?<br /><br /> LAST QUSTION <br /> At full throttle the rpms were at 5400 is this ok or do i need to change to a differant pitch prop??<br /><br /> James
