  #1
Old September 13th, 2003, 11:50 PM
txbasshntr txbasshntr is offline
Default 115 evinrude wont crank
I have got a real head scratcher. I have a 1971 evinrude 115hp that will not crank. I started with no spark and replaced power pack. Now I have spark on all four cylinders but not at the same time. There is a warm up lever on control box and when lifted 3/4 up I have fire on only #1 and #3 cylinders and no fire on the other 2.But when you move lever down towards run position i get weak fire on all four at about 1/2 way up on lever and with lever down in run position I get fire on #2 and #4 but none on the other side. I have pulled flywheel to check gap at timer base and inspected stator and timer ok.Resistance checks ok on all componets and i replaced two cracked coils but it wont crank. It will hit and try to run for a second but thats it. Any ideas?
  #2
Old September 14th, 2003, 07:28 AM
Walker Walker is offline
Default Re: 115 evinrude wont crank
Clean up all your battery cable connections, clean all coil grounds and give it another try.
  #3
Old September 14th, 2003, 09:19 AM
Well i reloaded my guns and went to work on it again. I checked and cleaned all connections but no change so i did a little reading on this site a came across a similar problem that delt with plugs and their gap. Mine were set at.040 so i reset them to .030 and it actually crank up and ran for about 10 seconds then cut out and died. So what does this mean?
  #4
Old September 14th, 2003, 09:38 AM
The Marine Doctor The Marine Doctor is offline
Are your spark plugs wet? <---this will tell you if it is spark related.TMD
  #5
Old September 14th, 2003, 10:26 AM
Solittle Solittle is offline
Put some premix fuel in a squirt bottle and squirt some into the carbs next time it fires. If it runs troubleshoot the fuel system.
  #6
Old September 14th, 2003, 10:41 AM
all spark plugs are wet and it seems to be flooding i dont beleive there is enough spark to burn all fuel. when it does crank it will run poorly for a few seconds(dead hole/holes) then it sounds as if the other cylinders are trying to kick in but it just pumps out a lot of smoke and dies could my problem be the spark plugs?thanks for all your advice this thing has been drivin me nutsi will have to try to bottle feed it to see if it makes a difference but i think im getting plenty of fuel(extremely wet plugs)
  #7
Old September 14th, 2003, 11:35 AM
Hooty Hooty is offline
You mentioned spark plugs in your last post but didn't say if you had replaced 'um, so do that. Install the factory recommended Champion plugs gapped at .030" and give it a try.c/6Hooty
  #8
Old September 14th, 2003, 12:46 PM
just replaced plugs and it cranked up and ran for about a minute then same as before died out my #2 and #4 plugs are not firing at all when it run but i get weak fire with them out am i looking at buying another power pack or do i need to look more towards the stator/timer basethe #1 and #3 plugs are firing fine. If i switch brown leads from stator should the oppistite plugs fire? i have tried to switch sensor leads but they are not long enough.
  #9
Old September 14th, 2003, 01:02 PM
I guess my question is this. What does the warm up lever have to do with the firing of the plugs?I come from a back ground in electronics and automive ignition systems and in my experience it shouldnt matter where the timer base is located, it should still fire the plugs just not (on-time)but i lose fire between the banks as the timer base is rotated. This is the problem i need to solve. Thanks again for your help!
  #10
Old September 14th, 2003, 01:23 PM
Im trying not bore or bother you nice folk but now i have another problem. I have a fluke 87 dmm and it is supposed to have min/max and peak capture modes and when i try to test out put of stator and/or timer base it shuts my meter off while cranking the motor over. Whats up with that?
  #11
Old September 14th, 2003, 01:25 PM
Do you have the meter set on AC or DC?c/6Hooty
  #12
Old September 14th, 2003, 02:24 PM
it is in ac voltage and ive tried to set range instead of auto
  #13
Old September 14th, 2003, 02:28 PM
i would hate to put it in the shop and they just replace everything a charge me an arm,leg and kidney. I have a clymer repair that has less info in it than i can find on the net. Any suggestion for a GOOD repair manual?
  #14
Old September 14th, 2003, 02:30 PM
btwthanks for your insite Hooty
  #15
Old September 14th, 2003, 02:42 PM
Set the meter on DC voltage.c/6Hooty
  #16
Old September 14th, 2003, 02:48 PM
Sounds like the stator is dying on one side...or the powerpack is failing...swap the stator leads around...see if the other side starts to fire.TMD
  #17
Old September 14th, 2003, 03:00 PM
ok here we go i tried it on dc across brown/brownyellow and it shut of meter so i put common lead to groud and measured each brown wire. I got -178v on one leg and -288v on the other leg then i retested and got the same -178v on leg and -38v on the other. same results after a few tries. i tried to reverse leads to get a + result and it shut off my meter. I am not sure that this meter can accurately measure the peak voltage as it can only sample at 100ms.
  #18
Old September 14th, 2003, 03:08 PM
i have reversed stator leads and now i get both sides firing all the time no matter where the warm up lever is. but i have intermitten firing on one bank instead of no fire at all
  #19
Old September 14th, 2003, 03:35 PM
k0mptec k0mptec is offline
sleep on it and try again in the AM... it sounds like it has given you all kinds of heck today
  #20
Old September 14th, 2003, 04:30 PM
one more post after switching stator leads it cranked and idle and will continue to idle but now #1 and #3 are dead but it stays running. Will not accelerate but it does finally purr a little. Am I in need of a new stator? Thanks a lot you guys for putting up with me
  #21
Old September 14th, 2003, 05:40 PM
Yep. That 38v's you got looks like a bad charge coil. Stator time.c/6Hooty
  #22
Old September 14th, 2003, 07:50 PM
Thanks for the info Hooty ill let you know how it turns out
  #23
Old September 17th, 2003, 12:58 PM
back againafter extensive testing and replacing both stator and timer base i still have problems stator didnt change anything after new timer base was installed i now have good fire all around but it is hesitant to crank and still runs on two cylinders but it will catch all four ever once and a while
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Wont crank at all dsinger PWC (Jetskis, Waverunners, etc.) 5 April 4th, 2007 08:48 AM
wont crank after ran 1 or 2 times tammy_smith538@yahoo.com Mercury & Mariner Outboards 2 February 6th, 2007 09:50 PM
Starter wont crank pschambs Johnson & Evinrude Outboards 1 November 15th, 2005 06:36 PM
70HP Evinrude Wont crank miichael18 Johnson & Evinrude Outboards 2 March 24th, 2004 09:00 PM
Wont crank over heyttown Johnson & Evinrude Outboards 2 October 23rd, 2003 08:58 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
