bbbuuuggg0
- Jul 21, 2003
- 18
I recently got a boat and motor from a friend, and it has no spark. He never even looked to see why, it sat for 4 years with out being run and has a lot of corrosion. Its a '59 Johnson 50hp V4SL-11B, elecrtic start magnito ignition. I got a Seloc repair manual and it doesnt have a wiring schematic for that year, all it shows is a genaric diagram. I've already reset the points, but the manual doesn't describe how to test the coil it just says to have it tested at a shop. If the points,plugs,wires,cap and rotor are good and the kill switch is disabled then all that is left is the coil right? Unless there is a broken wire. Or am I looking at this all wrong?
