  #1
Old August 6th, 2003, 04:50 PM
looking4amermaid looking4amermaid is offline
Default Evinrude Selectric Shifting Control Switch
I have a 1971 Evinrude ARROW GLASS boat, 14 foot 40 h.p. with a dash emblem named Phantom...my problem is it has a push button forward neutral and reverse switch, well when I went to pick up the boat the switch was stolen. I am now in search for what I am told may be impossible. I am also told that I can use a toggle switch so I am here now asking for advise from you out there knowing more than I do will a toggle switch work if so what wire will be correct as to hooking the switch up all the wires are togather in the shifter control unit. What does Dpdt and a separate switch has letters Spdt both of these are of a toggle switch I have found aftermarket. Does anyone have the wiring schematics of this and also I have a question as to the ignition switch I took it loose but not disconnected the wiring I see a gray wire that looks as if it has never been connected what is the function of this wire? Does anyone have the schematics of this also. I am willing to pay for all the hlep I can get and or tell me where I can buy these parts if they sale them as if from the factory or the toggle switch will work PLEASE ADVISE I need the help THANKS. Send information to mountainboy@peoplepc.com mountainboy@peoplepc.com
  #2
Old August 8th, 2003, 03:10 PM
Default Re: Evinrude Selectric Shifting Control Switch
Mr.AmigaDragon, I would like to know if you found this switch at a dealership in which they have more than one or is this a factory switch or aftermarket. I am told they stopped making these switches 1989, very rare to find...If you don't mind sharing the company name and phone number I can call to see if they offer an extra one. I would not and will not try to buy it if it is the only one they have and your needing it. I will wait and continue to search till it shows up...hopefully. Do you recall ever seeing a switch as the one I am describing the switch I am talking about is a three button switch behind the throttle lever. This switch is contained is a rectangular mount first button is forward - middle is neutral and rear is reverse. Is this what you have or can get. I am adding this as I am not sure if my last post reply was sent I tryed to move the prop turns about half a turn and I can turn it back to starting position. I am not sure what position it is in at the moment I bought the boat and I am doing pre-maintaince to it and I have came to this point. I dont want to hook a battery to it and it starts to cause any damages to the lower unit. That is why I asked about the gray wire in the ignition. I see it is disconnected and looks clean as if never hooked up. I do see a tach on the dash but too I never had the boat in the water so I am not sure if the tach is operational. It may sound like I got a piece of a junk boat but it just needs some minor stuff and it will be back to par. I HOPE with you help.
  #3
Old August 8th, 2003, 03:14 PM
Following Up!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Selectric / Hydro-electric control box monkeystealer Johnson & Evinrude Outboards 4 January 15th, 2007 11:26 AM
'69 Evinrude 55HP w/ Selectric switch will not reverse kauboy Johnson & Evinrude Outboards 30 September 1st, 2006 11:28 AM
Morse control shifting question on Evinrude kitebuz Johnson & Evinrude Outboards 16 July 31st, 2006 01:44 PM
johnson hydro/selectric control beach Johnson & Evinrude Outboards 7 September 30th, 2004 05:03 PM
'71Evinrure Selectric-shifting David Sick Johnson & Evinrude Outboards 6 September 30th, 2003 03:50 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
