Re: starter wiring harness
it is for the starter and electric choke. I have the harness but the positive cable for the starter has no insulation left from baking in the sun. The harness leads to the ignition box but has a disconnect at the base of the engine casing.<br />I need the inside the hood part with the male connector.
I just picked up a '57 35hp big twin, the outer cable is shot from sunbake, several broken wires etc, etc, only wire that was half good was the hot wire to the starter!
Plans are to remove it and wire direct bringing my wire out the side where that plug is, I have a 30hp BT the wires come out through that big hole in the base but they always seem to be in my way! There are 4 small wires and pins + the hot wire to the starter! This is the plug that bolts inside the motor case real close to the starter correct!
I am not going to use it, you are welcome to it just pay the shipping!
let me know!
Me thinks the 35 gets wired same way as my 30 hp, will find out tomorrow, I see no difference!
