small engine guy
- Jul 17, 2003
- 2
This engine has had powerpack replaced would run about 5 minutes an die,It had car coil on it we changed that,went through carbs,checked all wiring,and it started once good then after minute or so started missfiring bad. It dosent look like it has fuel pump but seems like fuel problem,spark looks real good.There is 2 sensors on it that have been disconnected,wich one goes to the little start switch on the throttle setup. I am unsure if i should hook those back up or what they do.
