  #1
Old September 5th, 2003, 02:59 AM
RetNav RetNav is offline
Default 1990 Evinrude 200 hp Big bore Looper
In the final stages at the shop rebuilding one of my motors and the mechanic wants to take the thermostats out and leave them out. He says we are in south Georgia and doesn't need them. Sometimes it gets real cold here too. Seems to me like if they weren't needed wouldn't have been designed with them in. Looking for opinions/reccomendations.
  #2
Old September 5th, 2003, 03:45 AM
93bronco 93bronco is offline
Ensign
Default Re: 1990 Evinrude 200 hp Big bore Looper
i wouldnt do it, they are there for a reason.but then if he does it will he warranty it from a future ph failure due to piston seizing , broken rings from excess carbon or cylinder scoring?
  #3
Old September 5th, 2003, 03:55 AM
rickdb1boat's Avatar
rickdb1boat rickdb1boat is offline
Agree with 2K BOAT. Make sure they put new ones back in. They are there to make sure the engine comes up to proper operating temp. Like you said, they are there for a reason! I would have to ask the Mechanic what his logic is as to why he would want to leave them out, other than you live in the south. Huumm!
__________________
Rick
"Boating is Life...All the rest is just Details"
  #4
Old September 5th, 2003, 04:46 AM
Joe Reeves's Avatar
Joe Reeves Joe Reeves is offline
RetNav.... I try not to ever criticize a fellow mechanic, however your mechanic's suggestion about the thermostats does raise some questions.(Thermostat Purpose)Many engines are considered high performance engines and demand a thermostat(s), and many smaller hp engines also require a thermostat for the following reason. The pistons actually distort/twist off round when running. The thermostat is required to keep the outer wall surrounding the steel cylinder, and the cylinder wall itself at a temperture to compensate for the distortion.With the thermostat removed, the difference in temperture between the inside the cylinder and the water jacket quickly reaches a point whereas (in effect) you have a oblong piston running up and down a round cylinder. Bottom line is without the thermostat, the piston and cylinder wall could be damaged in a short period of time.
  #5
Old September 5th, 2003, 04:57 AM
Hey guys, I really appreciate the quick response. I know that running a car without thermostats can cause overheating if stuck in traffic, etc... and figured the same of an OB. On these rudes it looks to be a simple fix as the t'stat is located at top (I think) of head and the bolts won't be hard to remove as the mech had to take them off to remove the tstats. I will get new and replace myself. Thanks again!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1990 Evinrude 120 looper boating2fish Johnson & Evinrude Outboards 1 January 9th, 2005 05:08 AM
1990 ?? 200 hp looper RetNav Johnson & Evinrude Outboards 4 September 6th, 2003 05:41 PM
Same 1990 200 hp looper RetNav Johnson & Evinrude Outboards 18 September 6th, 2003 04:53 AM
1990 200 hp Evinrude looper RetNav Johnson & Evinrude Outboards 4 September 3rd, 2003 02:20 PM
Thanks Dhadley- Small bore?/ Large bore? Sal G Johnson & Evinrude Outboards 2 August 1st, 2003 01:58 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
