fuel or air problem (no power)
oldxbiker
63 evenrude 40hp has no power at wot. I checked compression on both cilenders 110 & 110 psi, replaced plugs. checked spark, engine ran fine with choke cover open, when i closed cover the engine had no power. there is no air filter on this motor where do I start looking? [/LIST]
D
DJ
Guest
Re: fuel or air problem (no power)
biker,<br /><br />I would say that you are in need of a carb. overhaul.
