  #1
Old August 29th, 2003, 08:47 PM
cplugpiranha cplugpiranha is offline
Default 1977 Evinrude problem-clutch dog, prop, cables, linkage?
My 35hp Evinrude kicks in and out of gear before I even get to full throttle. It had a new clutch dog, carbs, foward gear, shift linkage and cables replaced in May. I have heard that my problem is in the lower unit,or the linkage, or even could be a screw loose on the shift lever, or even the prop. IS THERE ANY WAY TO IDENTIFY WHICH PROBLEM IT MAY MORE LIKELY BE? HOW (AND HOW MUCH$), WOULD I GO ABOUT FIXING THE PROBLEM?
  #2
Old August 29th, 2003, 08:54 PM
Hooty Hooty is offline
Default Re: 1977 Evinrude problem-clutch dog, prop, cables, linkage?
First thing I'd do is disconnect the shift cable from the shift lever, shift it into forward and see if it still jumped out. If it doesn't, the problem is in the shift cable adjustment. c/6Hooty
  #3
Old August 30th, 2003, 04:58 AM
rickdb1boat's Avatar
rickdb1boat rickdb1boat is offline
cplugpiranha Can you describe "Popping out of gear" a bit more. Does it start to go and then rev up or is there a distint "Pop" or thud when it comes out of gear? Reason I ask, is that if it just revs up and doesn't go anywhere, it could very well be a spun prop. Since you have replaced the other causes of the problem, it sounds like a prop problem at this point.
__________________
Rick
"Boating is Life...All the rest is just Details"
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Evinrude 90hp linkage problem Charles Bush Johnson & Evinrude Outboards 3 December 5th, 2006 03:05 PM
1977 115hp Johnson prop problem splichal5 Johnson & Evinrude Outboards 4 July 16th, 2005 09:55 AM
1977 Johnson 25 hp still slipping...clutch dog looks NEW. HELP! csgrizz Johnson & Evinrude Outboards 12 July 11th, 2005 07:33 AM
78 Evinrude 140 hp- Problem w/Newly Installed Throttle Cables...or ??? brettagostini Johnson & Evinrude Outboards 3 July 30th, 2004 06:20 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
