JamesCoste
- Jun 15, 2003
- 595
1983 50 HP Johnson motor:<br /><br />I put my rebuilt boat into the ocean for the first time in 4 years. On day 1, the motor would not get on a plane easily, but would sputter, plane, then 30-seconds later choke down and go into idle. It appeared to be an electical problem with the ground wire going to the power pack.<br /><br />On day 3, I fixed this wire and went out again and the boat worked GREAT all afternoon long.<br /><br />On day 6, my father-in-law took out the boat and it ran poorly (similar to day 1).<br /><br />I bought 2 carb kits (for $17 a piece) and a manual and want to rebuild them. My neighbor said that one of the coils is probably going "bad" and the carb is probably okay. I'd rather not have to rebuild the carb if they are okay. Before the gentleman who previously owned the boat died, he had the boat shop "winterize" the motor and it has sat up for 4 years.<br /><br />What would you do?<br /><br />1. Rebuild the carbs, take it out and see how she runs?<br /><br />2. Buy two new coils ($30 a piece), replace them, and take it out? If she runs good, return the unopened carb kits?<br /><br />3. Buy two new coils and rebuild the carb anyhow?<br /><br />Do I need to replace the fuel lines as a good measure as well?<br /><br />The motor idles well, will get up on a plane and run good for a while, the bulb on the fuel line stays firm (I don't think there is a fuel leak), and it cranks easily.<br /><br />Here's my first post here and a little more detail: Initial diagnosis from this board
