Re: Need help...Johnson fuel line
Sorry to say you won't get much for it. 50's era engines aren't really considered antiques by collectors. Or at least they don't pay antique prices. Fortunetly though, lots of parts are still available.<br /><br />My advice would be to get it running and enjoy. <br /><br />If gas was left in the tank or carburator, after four years it's probably gone bad and turned to varnish. The carburator must be cleaned *spotless* inside and all it's little passages clear of crud if it's going to do it's job. This is done by disassembling the carb, removing all rubber and plastic parts, and then soaking in carb cleaner. After the soaking, you blow out all the passages with compressed air. Could be that the fuel filter or tank pickup screen is clogged too.<br /><br />If you suspect you have fuel delivery problems, you can fill a spray bottle, like a perfume bottle, with 24:1 mix and spray some down the carb throat. If it starts on that then you know you have fuel problems.<br /><br />You're soon going to want to track down a manual for yourself. Iboats will sell you one, but you can probably get one off ebay for a little trouble. Also, public libraries often have them. Try the reference section.<br /><br />Two words of warning: <br />1) Although you have good spark, the ignition coils under the flywheel are probably cracked. If any moisture gets to them they'll stop working. New ones can be had for as little as ~$15 each. You'll need two.<br />2) The waterpump impeller is probably wrecked from sitting. You definitly want a new one of these.<br /><br />Good luck!
