Re: evinrude- pee hole isn't shooting water in hight speed
LongLake.... That model number indicates that the engine is a 1971 model, but that model does not have a water telltale outlet. You don't say exactly what you had done last year, but the explanation you give (if the engine is overheating), would indicate that the water pump is failing. If, last year, you simply had a impeller installed, have it redone and install a complete water pump kit.
