Float level?
jcoo240811
I have just bought a non-running johnson 5.5hp<br />model# cd-20R made in 1963.I have got it running buy cleaning the carb but it is running real rich.I read that the initial hi and low speed settings should be set a 1 complete turn for the high speed needle and 1 1/2 for the low speed needle and i did this but to get it running half way good I had to close them almost all the way,but it seemed to still be running too rich.Could this be the float leveland if so how would I set it?
Joe Reeves
Re: Float level?
Hold carb upside down. Adjust float so that when viewed from the side, the end opposite the hinge pin is slightly higher (off level) and that when viewed from the end, it is not cocked.<br /><br />Adjust the carb as follows:<br /><br />(Carburetor Adjustments - Two Adjustable N/Vs) <br /><br />Initial settings are: Bottom high speed = seat gently, then open 1 turn out. Top slow speed = seat gently, then open 1-1/2 turns. <br /><br />Setting the high and low needle valves properly: <br /><br />NOTE: For engines that DO NOT have a shift selection, obviously there is no NEUTRAL position. Simply lower the rpms to the lowest setting to obtain the low speed needle valve adjustment.<br /><br />(High Speed) Start engine (it will run pretty rough), shift into forward gear, take up to full throttle. In segments of 1/8 turn, waiting for the engine to respond between turns, start turning in the bottom high speed needle valve. You'll reach a point whereas the engine will either start to die out or spit back (sounds like a mild backfire). At that point, back out the needle valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest setting. <br /><br />(Low Speed) Slow the engine down to where it just stays running. Shift into neutral. Again in segments of 1/8 turns, start to turn the top needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running. Eventually you'll hit the point where the engine wants to die out or it will spit back. Again, at that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting. <br /><br />When you have finished the above adjustments, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.
