Re: Johnson Identification
Thank you very much. Now specific questions if you folks have the time and patience for a greenhorn. <br /><br />First, when running,without twisting the throttle, it'll kick down to a slower speed out of nowhere. Any idea why?<br /><br />Second.there is a small hole in the lower unit on the underside of the area above the prop. It was dripping a yellowish fluid. Is this normal extraction and what is the purpose of the hole?<br /><br />I just filled the lower unit with lube and the person who gave me the motor said I have to keep an eye on it as some water is leaking in at present? Is this tied to the yellow discharge?
