87 200hp johnson<br /><br />I performed a compression test.<br />cyl 1 80lbs cyl 2 95lbs<br />cyl 3 70lbs cyl 4 90lbs <br />cyl 5 80lbs cyl 6 90lbs<br /> <br />I called johnson outboards and the person I talked to said 75 to 90 would be a good range but I felt it was a little low. I pulled off the gasket and found the #3 cyl to be very loose almost like there was no rings left but all of the other cyl were fine. The gasket on that side was almost gone. The question I have is can you replace the rings without having to bore the cyl. The pistons look very good and the walls have a very little shine to them. Also does anyone know what the correct compression should be for this type of engine. <br /><br />thanks
