I have a 1979 Johnson 175 (after talking to mechanics it may be a 150). The engine needs a complete rebuild, which I can have done for $2200. (as long as crank is OK) <br />I have the opportunity to purchase a 1980 model Mercury 200 on a 18' Checkmate w/ trailer for $3000. This motor had a complete rebuild a couple of years ago. I took it for a test drive and it seemed to be OK. It did start immediately when cold. (Something the Johnson nver did!) I did notice that the motor was louder (had more bark!) than the Johnson. I did have soundproofing on the Johnson cowl, so this could be part of it. Also, the Merc has external power trim, which I guess is OK, but it is also kind of loud.' It does have dual cable steering, and a concealed control box.<br /><br />I am considering buying this and swapping the motors, and then reselling the Johnson motor and Checkmate. I plan on doing the swap myself.<br /><br />Is this a good idea?? I'll have to swap all of the control cables. Also, will the motors fit on the same holes on the transom.?<br /><br />What about this model and year of Merc?<br /><br />Thanks for any insight. I would like to decide in a couple of days.<br /><br />Rick
