  #1
Old August 19th, 2003, 08:40 PM
zepper39 zepper39 is offline
Default 1987 Evinrude 48 Sp has no RPMs
I'm new to boating and found this excellent site. I've searched and found many simular posts, but none exactly the same. Repair manual's on order, but checking for obvious problems first.Motor is 1987 Model E48ESLCUS. Motor starts, idles and runs fine, but only develops 2000 rpm at WOT. Tried primer bulb - bulb was hard and made no difference. Choked and RPMs jumped up to 4000 and ran smooth as long as choke was engaged. Can get another couple of hundred RPMs by feathering choke, but as soon as choke is let off - right back to a steady 2000 RPMs. Noticed by accident that in reverse RPMs would go to 4000 without choking.Boat had been setting for several months with no fuel. Flushed tank and refilled before starting. Have since checked carbs best I can without removing and found no obvious signs. Checked external fuel filter and screen over fuel pump intake and found no problems. I suspect that the carbs need pulled/cleaned and am waiting on the manual before removing. Did not check the compression (no guage) but motor seems to run o-k when it gets fuel. Did pull the plugs and they were a little on the wet side with a kind of light brown color.My questions are: Am I on the right track? What else should I be checking? Any help will be greatly appreciated.
  #2
Old August 19th, 2003, 08:51 PM
ob ob is offline
Default Re: 1987 Evinrude 48 Sp has no RPMs
Boris,Yes ,I think you are on the right track.When you get your manual and begin the carb removal and rekitting or cleaning ,post back if you have further questions and someone will be glad to help.
  #3
Old August 19th, 2003, 09:09 PM
Thanks, OB, I'm sure I will.One puzzling question that I forgot to ask is why it will run in reverse but not forward? It seems that if there is a problem with the carbs it wouldn't matter whether it was forward or reverse?Also, I can idle for a period of time and then go to WOT and it will go to about 3000 rpm and act like it's going to run and then just ease right back down to 2000.Thanks again.
  #4
Old August 19th, 2003, 09:14 PM
ob ob is offline
Two reasons for the reverse performance.One is that the engine is not subjected to as much load driving the prop in resverse,particularly on thru hub exhaust.Second ,the throttle plate travel is only around half of what the forward gear position is.Symptom sounds like a classic case of fouled carbs.
  #5
Old August 19th, 2003, 09:18 PM
Great. At least it confirms my suspicions. Can't hardly wait for the manual. It'll be a few days, but I'll post back with findings.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1987 Force 125 HP Overheating at high RPMS agropic Force & Chrysler Outboards 0 August 29th, 2006 03:45 PM
1987 dt85 alarm at high rpms river37091 Yamaha & Suzuki Outboards 5 July 27th, 2005 12:59 PM
WOT RPMs 77 Evinrude 85 hp jmcgill89 Johnson & Evinrude Outboards 10 September 17th, 2004 05:36 PM
90 Evinrude rpms... Lakeshore82 Johnson & Evinrude Outboards 3 July 6th, 2004 07:57 AM
rpms on 64 evinrude 9.5 gtcjon Johnson & Evinrude Outboards 1 May 30th, 2003 01:00 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
