  #1
Old August 19th, 2003, 07:54 PM
no-float-boat no-float-boat is offline
Default old Evinrude smokes and chugs
i have an old evinrude number 35545 50098. i would like to find out the year. this motor starts great but smokes and wont accelerate. When throtle is applied it smokes worse, spits oil and chugs ???????? i would appricate any feed back. thank you
  #2
Old August 19th, 2003, 08:30 PM
ob ob is offline
Default Re: old Evinrude smokes and chugs
no-float-boat,Check the model number again.I can't find a 35545.As for the chugging and poor engine response I would start with a compression test.Look for compression numbers near 100 and within 10% on all cylinders.
  #3
Old August 20th, 2003, 10:54 AM
oldboat1 oldboat1 is offline
Ensign
What horsepower? Model number doesn't check out -- early 60's 40 hp?Offhand, you might clean and regap the plugs, then change out the gas (fresh gas with the right mix of TCW-3 oil -- depends on the model year.) You may have too rich an oil mix, or the choke might not be disengaging.
  #4
Old August 21st, 2003, 11:26 AM
Im sorry guys, the number is 35515 50098. the hood says 35hp Lark. im using a 50 to 1 oil mix. 480ml(oil) in 21L(gas). oil is motomaster Formula 1 premium 2-cycle outboard oil TC-W3. plugs are new, compression is good. i will check again and post numbers. Should i try a lower oil mix? 75-1 or 100-1? Also where should she pee? i cant see any water spitting out. thank you
  #5
Old August 21st, 2003, 11:59 AM
pulled plugs, very oily. compression is: top cylinder is 124, botton is 122.thanks
  #6
Old August 21st, 2003, 12:19 PM
ob ob is offline
35515 is a 1958 35 hp engine.Mix is 24:1.
  #7
Old August 21st, 2003, 01:18 PM
Ensign
24:1 to 32:1 -- That's four to five ounces of oil for each gallon of gas. Water is exhausted from the port on the rear of the leg, about halfway down. It will spray a lot of water if the pump is working right (Water and exhaust also exits underwater from the port under the ventilation plate.) If you don't have water coming out from the back of the leg, you need to pull off the lower unit and check the impeller (might as well replace it even if it looks OK). In addition, check for obstructions in the leg. Exhaust backing up will give you the conditions you describe, and the back pressure will not permit the motor to run well (if at all). You may have a mouse nest in the leg -- no kidding; been there, done that.
  #8
Old August 21st, 2003, 05:55 PM
Reel Appeal Reel Appeal is offline
This may be a stupid question,i know, so please forgive me. Are you thoroughly mixing the oil in the tank? If oil is not put in first or not mixed it will settle on the bottom of the tank,just waiting for the pick-up tube.Also,would someone please explain to me why older outboards require a richer mixture than 50:1? Thanks for the info....
  #9
Old August 21st, 2003, 07:46 PM
ob ob is offline
Reel Appeal,Many of the older outboard engines did not incorporate open design low friction needle bearings on the internals.For this reason a richer oil mix was factory recommended in those days to assure enough in the atomized mix to enable enough lubricant to migrate between the friction surfaces of their babbit type bearings.Whether a person who owns one of these engines decides to use a leaner mix to attain less smoking or a bit more combustion performance is a decission that I personally will not recommend and leave it to the individual to decide.In some cases one may be able to get away with it and in some cases perhaps not.
  #10
Old August 22nd, 2003, 12:53 PM
Great. Thanks alot guys. Youve been a great help. im hoping to get her in the water within a week. ill let you know how she runs. thank you very much
  #11
Old August 22nd, 2003, 06:20 PM
That makes sense ob.Thanks for the info.....
  #12
Old August 25th, 2003, 10:32 AM
Went for a ride. would not fast idle. starts and runs on slow idle beautifully. no speed. should i try to clean out the carb?? What are the needle setting? 1968 evenrude 35hp lark. any other ideas of what it may be??
  #13
Old August 25th, 2003, 10:33 AM
also, where would i be able to find a manual for this motor? if thats posible.
  #14
Old August 25th, 2003, 10:41 AM
TimW TimW is offline
Try e-bay for the manual. Last time I checked there was a guy selling reproductions of most of the original Envinrude shop manuals from the 60's and 70's for around $10.
  #15
Old August 25th, 2003, 10:42 AM
SeaMasterZ@aol.com SeaMasterZ@aol.com is offline
iboats has em, so does amazon, barnes and noble, just do a search for em, youll find tons of emon the oil situation, one of the gurus on here says that the reason the old motors are still around is cause of the heavy oil mix ... more lube, less wear, makes sense to me, Im going to run my 50 - 1 motor at 32 to 1, cant hurt and should help it in the long run
  #16
Old August 25th, 2003, 10:47 AM
ob ob is offline
No need to run your later engine 32:1 instead of 50:1.Your engines open bearing design allows for ample lubrication at 50:1.Over oiling will lead to premature carboning.
  #17
Old August 25th, 2003, 01:18 PM
does anyone know what the needle settings are??
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1988 Evinrude smokes low rpm pcangler Johnson & Evinrude Outboards 2 April 17th, 2006 02:08 AM
1997 25 HP Evinrude smokes when hot HarleyXL Johnson & Evinrude Outboards 4 September 7th, 2004 11:40 PM
Merc. chugs but won't run? philtheskipper Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 21 November 22nd, 2002 02:56 PM
Evinrude 175 smokes alot DM Johnson & Evinrude Outboards 6 July 11th, 2002 06:36 AM
Evinrude 175 smokes alot DM Boat Topics and Questions (not engine topics) 0 July 10th, 2002 10:15 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
