Jmorrell588
- Jul 20, 2002
- 61
1989 Evinrude 90hp V-4 Crossflow.....<br /><br /> My Tilt and Trim is making a whinning/groaning sound when raising it while sitting still. Almost as if the battery was low. Once it reaches the first extension, it thens sounds normal. Lowering the unit seems fine with a slight whine. What might cause this sound? The Trim & Tilt motor going out or maybe the Relay's? Maybe air in the system?<br />Also note! I see the trim and tilt gauge kind of stuter when I trim when boat is in motion.<br /> I have noticed that while giving the motor gas and just getting up to plain, you can feel the motor knock. Almost like the shift lever is out of adjustment but I do think that it is the trim and tilt. <br /><br /> Any help is so very welcomed....<br /><br /> Jimmy
