  #1
Old August 18th, 2003, 01:05 PM
dajen dajen is offline
Default 1982 70hp Evinrude 3 cyl spring location on fuel/choke linkage, need photo if po
This is on a 182 Evinrude 70HP 3cyl E70-ELCNBThere are two linkages that connect to all 3 carbs. The one closest to air intake is most likely the choke, since it is activated by the electric choke (pushing key in) The second linkage might be fuel and is located just to the front of the choke linkage and it is also connected to the 3 carbs. At the center of the "fuel" linkage (adjacent to center carb) there is a spring that is loose and looks like it should be attached to the choke linkage, but I cannot be sure. Does anyone have a picture of those linkages that shows that spring (it is a circular spring, rather than a long coiled spring) I would buy a manual, but I am not sure is will have that picture. Should I buy an OEM manual specific for that year or will the "generic" manuals contain what I need. Thanks, Don
  #2
Old August 18th, 2003, 01:18 PM
Dhadley Dhadley is offline
Location: Port Charlotte FL (almost -- its coming along)Never mind - it'll never be the same
Default Re: 1982 70hp Evinrude 3 cyl spring location on fuel/choke linkage, need photo i
Welcome aboard!!The end of the spring does not attach to anything. Strange, huh? Heres the deal -- if for some reason the choke (forward) linkage should hang up and not open completely, as you open the throttle (rear) linkage the "arm" of the spring will push, or try to push, the choke linkage open. You wouldnt believe the places we've seen folks try to put them. Good question!
  #3
Old August 18th, 2003, 08:24 PM
Dhadley,It might have been a good question, but it was an even better reply. I had a friend try to place it against the choke linkage in such a way as to possibly jam the choke closed. I was able to find the OEM service manual for that year and have ordered a copy. Thanks for spending the time to answer my question.Don
  #4
Old August 19th, 2003, 04:07 AM
Youre very welcome!Dont be afraid to share your new manual with your buddy. Lol!Good luck and happy boating!
  #5
Old May 25th, 2009, 08:12 PM
allenboats allenboats is offline
Default Re: 1982 70hp Evinrude 3 cyl spring location on fuel/choke linkage, need photo if po
Sir,
I believe I have a similar problem with a spring on the throttle linkage of my 1972 65 hp evinrude. Did you ever come up with a picture of the linkage that is clear enough to see the spring?
If so would you share it with me?
Thanks in advance.
Allen
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1977 70 HP choke spring installation location? Tpayneful Johnson & Evinrude Outboards 5 August 18th, 2006 11:17 PM
81 Evinrude 70 Choke Linkage dmadey Johnson & Evinrude Outboards 2 June 3rd, 2006 07:23 AM
1962 Evinrude 40 HP choke linkage? Neebar Johnson & Evinrude Outboards 2 April 23rd, 2006 12:39 AM
choke linkage for 1982 70 hp johnson ferrans Johnson & Evinrude Outboards 4 July 5th, 2004 06:21 AM
Spring helped, Fuel bulb ??74 Evinrude 115 Choke issue? Pst76 Johnson & Evinrude Outboards 8 September 6th, 2002 05:45 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
