'79 johnson 70 hp lost wot
jstart1
Idles fine, seems fine on garden hose, but when in the lake severe loss of power. New plugs, cleaned carbs, and one leaky fuel line feeding bottom carb. Could a leaking gasket on the air cover be doing it all? Or should I go back and start at the carbs?
Joe Reeves
Re: '79 johnson 70 hp lost wot
Jstart.... If you have approx 100+ psi compression on all cylinders, and (w/plugs out) spark that will jump a 7/16" on all cylinders, in all probability your carburetors are fouled and will require cleaning etc.
