115 Johson 1977 model starter motor problems
ckorenek
I have a Robalo with twin 115 Johnson's. I am having a problem with the starter motor on the port side. I've changed sylnoid and tried a different starter with the same results. When I turn the key over the starter just spins and will not engage the flywheel. If I connect directly to a battery with jumper cables, it pushes out the starter gear and engages the flywheel and turns the motor over. It seems to be a grounding problem. Any suggestions are welcome.<br /><br />thanks
Walker
Re: 115 Johson 1977 model starter motor problems
Its most likely either your battery cables or cable connections to the enguine and battery. First step is to clean all battery cable connections.
