  #1
Old August 17th, 2003, 04:04 PM
pooz pooz is offline
Default 85 hp evinrude starts but won't stay idling
First time at this forum - appreciate any help I have a 1980 85hp evinrude - was running great just a few weeks ago. Now, it starts fine when I use the idle lever, will rev up to 4500rpm, but dies when I bring the idle lever down to normal "run" position. I tried pushing the idle lever down quickly and putting it into gear before it died and it stayed running, but won't get any power - stays below 2000rpm at full throttle. It seems like it starving for gas or "sucking air". I changed gas, gas lines, fuel filter screens, etc. No Luck. This motor runs too strong to be put out of commission because of a bad idle problem. Any Help?
  #2
Old August 17th, 2003, 06:25 PM
Solittle Solittle is offline
Default Re: 85 hp evinrude starts but won't stay idling
You might try squirting some pre mix directly into the carbs when it starts to die. If it perks up: http://www.outboardrepairs.com/carburetors/
  #3
Old August 17th, 2003, 06:27 PM
The Marine Doctor The Marine Doctor is offline
If there is an "Air leak" problem...the spark plugs with be a dry tan/white.I would suspect that something has plugged up one of the low speed jets.Time to remove the carbs and get them fixed up.A way to check for this....press the choke as the engine starts to die...this will tell you if its a lean condition.TMD
  #4
Old August 18th, 2003, 11:24 AM
Marine doctor - thanks for the tip - but it seems to me to run too rich - not lean. smokes, gas on the water around the motor, etc. Someone told me about a rubber diaphragm behind the fuel filter- if it tears, it won't run right. Any thoughts? Also, if the carbs are dirty - does it happen that suddenly? like I said, motor ran terrific last time I took it out a few weeks ago. Another piece of info - after I ran it a few eeks ago -it went into the shop for repair. Power trim ram was leaking fluid. Got two used rams put in and no more leak, but now motor is messed up. Could the shop have bumped something under the hood that would make the motor run bad?
  #5
Old August 18th, 2003, 11:28 AM
Do a compression test and spark check on the engine.Them get back to us.TMD
  #6
Old August 18th, 2003, 06:50 PM
dulind dulind is offline
the last suggestion of the spark test is a great one, i was having an identical problem with my 135hp due to a bad sensor coil shutting down two cylinders.
  #7
Old August 19th, 2003, 01:32 PM
Marine doctor - thanks for the suggestion. When you say do a spark check, do you mean just grounding the plug and cranking the motor to see if it sparks, or is there a more involved test that I'm not aware of. Thanks
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1984 Evinrude 30hp starts but won't stay started. Gorilla978 Johnson & Evinrude Outboards 13 June 26th, 2008 10:40 PM
200 hpdi cold starts rough idling Fish-T-Cuffs Yamaha & Suzuki Outboards 5 May 22nd, 2006 09:07 AM
60 hp Evinrude dies while idling Holdimhook Johnson & Evinrude Outboards 5 June 30th, 2005 03:34 PM
Starts, but won't stay running billtheprinter Johnson & Evinrude Outboards 1 May 27th, 2005 11:20 PM
Johnson 97 150 HP Ocean Runner starts idling fast when engine is hot ecelani Johnson & Evinrude Outboards 6 August 20th, 2003 10:13 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
