  #1
Old August 15th, 2003, 07:37 PM
sray sray is offline
Default 73 Evinrude 50 hp Lower Unit Repair
After giving up on obtaining a used lower unit I have undertaken the disassembly of the damaged one. I have gotten to the point where the driveshaft and pinion must come out to remove the gear and shift mechanism. The unit set dry for some time due to the case freezing and cracking. All shafts and gears so far are smooth and crisp but bearings/seals are shot. I have removed the four bolts and the top bearing plate on the driveshaft and can turn it a little and it moves up and down about 1/4", but will not pull out. The information I have shows a set screw, but the one I have removed doesn't seem to help. It was in the water intake area. What do I do to remove the driveshaft? The shift mechanism is also stuck won't move up or down. The prop shaft will turn and the pinion is not engaged.Thanks
  #2
Old August 15th, 2003, 07:50 PM
Skyhigh Skyhigh is offline
Default Re: 73 Evinrude 50 hp Lower Unit Repair
You must remove the pinion nut. Special tool OMC No. 311875 is required to turn the driveshaft in order to remove the pinion gear Nut.If the special tool is not available, clamp the driveshaft in a vise equipped with soft jaws, in a area below the splines but not in the water pump impeller area. With the proper size wrench on the pinion gear nut, rotate the complete lower unit COUNTERCLOCWISE....
  #3
Old August 15th, 2003, 07:51 PM
OBJ's Avatar
OBJ OBJ is offline
Sray....the little screw near the water intake holds the lower drive shaft bearing race in place.You must remove the pinion nut and then the pinion gear before the driveshaft will come out.
__________________
When in doubt...use the manual
Rayland, Ohio....Along the Muddy Banks of the Mighty Ohio River.
  #4
Old August 15th, 2003, 07:58 PM
Thanks for the help. The driveshaft won't rotate. So the nut can't come off by holding it and turning the shaft. I sure can't see how that set screw would hit a bearing, it seems so far from the centerline of the shaft. I have put quite a bit of rotating force on the drive shaft to try and turn it and it's froze, it will move up and down slightly. Any other suggestions?This has got to be better than any manual. I have a generic Evinrude manual, it doesn't show the problems you might incounter.
  #5
Old August 15th, 2003, 08:04 PM
Have you removed the water pump and the seal housing?
  #6
Old August 15th, 2003, 08:08 PM
Yes, i[ve removed the fou bolts and the top Bearing and seal assembly. I can see where the shaft get considerably larger. The shaft will shake form side to side at this point and move up and down.
  #7
Old August 15th, 2003, 09:00 PM
Where'd all my great help go, we were on a roll. It can't be so late that you've given up for the evening. I'd still like to know what is holding that shaft from turning or how much force it will stand to turn it without damage.Thanks
  #8
Old August 15th, 2003, 09:04 PM
OBJ's Avatar
OBJ OBJ is offline
Sray...if the driveshaft moves up and down and side to side....it should turn unless somethind is binding the pinion gear or the driveshaft bearings are chewed up into the drive shaft. The bearing race set screw sets in ontop of the race. Weird I know....but thats' how it is.I would try and get a box end wrench on the pinion nut and try to losen it. It must come of if the drive shaft is to be removed. If you don't have special tools or a soft jawed vise, you can use a pipe wrench (somebodies going to say something about this) on the part of the drive shaft that doesn't have splines or have a sealing surface. Any marks can be cleaned up later with a file.
__________________
  #9
Old August 15th, 2003, 11:57 PM
The Marine Doctor The Marine Doctor is offline
For shame...the dreaded Pipe Wrench.If its done carefully..its should be fine...just try not to let it slip.You could though...try a vice grip farther down the shaft.Also...take note it was mentioned that it will not shift either...I would think there is some gear damage done and that is preventing the shaft from turning.TMD
  #10
Old August 16th, 2003, 04:07 AM
OBJ's Avatar
OBJ OBJ is offline
I'm all a'shamed
__________________
  #11
Old August 16th, 2003, 06:42 AM
Thanks for everyones help. I still can't believe the knowledge that's available on this site.Guess it proves that "not one of us is as smart as all of us".I'll put the suggestions to use today and let everyone know how it works out.Thanks again.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Lower Unit Repair DIY Job? landig Johnson & Evinrude Outboards 2 September 18th, 2003 03:37 PM
73 Evinrude 50hp Lower Unit Repair sray Johnson & Evinrude Outboards 2 September 14th, 2003 04:11 PM
lower unit repair ReeseK Johnson & Evinrude Outboards 2 September 13th, 2003 03:10 PM
73 Evinrude 50hp lower unit repair sray Johnson & Evinrude Outboards 8 September 9th, 2003 09:45 AM
115 hp evinrude lower unit repair? jennis Boat Topics and Questions (not engine topics) 2 June 13th, 2001 08:37 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
