1969 Johnson 40, electric shift diode
croboat
I have 1969 Johnson 40HP. My brilliant mechaniker lost original controls and replace it with other, obviously for other engine. I compare it with SELOC's manual and found differences: there is a diode for shift or something (not in manual), and shift switch give me continuity in neutral position with backward ?! (I understand it as activated backward coil when control is in neutral)(in manual state that it should be no continuity to either coil). What should I do? (Sorry for grammar, I'm from Croatia).
Joe Reeves
Re: 1969 Johnson 40, electric shift diode
CroBoat.... Your brilliant mechanic has given you the controls for a "Hydro Electric Shift" unit instead of the proper straight "Electramatic Shift" controls.<br /><br />When the ignition key is turned to the off position on the "Hydro Shift" unit, 12v is applied to the neutral shift solenoid through that shifting diode in order to keep the unit in neutral via the charging circuit until the engine stops turning. Since the default on the Hydro units is to be in forward gear when no voltage is applied, if this diode wasn't there, the engine/boat would lurch forward the instant the key was turned to the off position.<br /><br />Your engine (Straight Electric Shift) does not require this function.<br /><br />If you are to keep that set of controls, disconnect that wire and discard it and the diode. Tape it out of the way somewhere.<br /><br />Also, you cannot use that shift switch as it is not wired internally properly. You will need to exchange it for the straight electric type shift.<br /><br />--------------<br /><br />The Hydro shift switch wiring is as follows:<br /><br />Forward = No Voltage to either wire.<br /><br />Reverse = Voltage to Green and Blue shift wires.<br /><br />Neutral = Voltage to Green shift wire.<br /><br />---------------<br /><br />The Electramatic shift switch wiring is as follows:<br /><br />Forward = 12v voltage applied to Green wire.<br /><br />Reverse = 12v voltage applied to Blue wire.<br /><br />Neutral = No voltage applied to either wire.<br /><br />Curious.... Just how does a mechanic lose a complete set of controls???
Joe Reeves
CroBoat.... If it gets to a point where you simply need a "Electramatic" shift switch and can't locate one. I do have one new one left in stock. ReevesJ32@aol.com
croboat
Joe Reeves, many thanks for your answer. Yes, this is what I measured. I have to think now, if I could use this switch rewired. Also, I'm afraid that one ignition coil is burned. What is the easiest way to reach those parts (I could hardly find it here, only if I find the same old engine out of function and buy it)?
Joe Reeves
CroBoat... In order to use the Hydro Electric Shift switch, you would need to rewire it internally. Hopefully you can do just that or find a good used one somewhere. Others here at "iboats" may know where you could pick one up, also the coil you need as I don't have a coil for that model left in stock.<br /><br />The new "Electramatic Shift" switch that I do have... If you're interested in it, contact me via my e-mail address of ReevesJ32@aol.com .
