Do I need to bore cylinders or just hone?
Tinkerer
1967 60 HP V4 Evinrude - The saga continues ....<br /><br />Pulled one head and two cyls scored. Not worth cost of new pistons.<br /><br />As the block was potential landfill anyway, I gave one cyl a rub with 120 grit wet and dry paper and light oil and lo and behold, 90% of the score marks disappeared when I got through the glaze to clean metal.<br /><br />I'm guessing that the unburnt fuel was getting past the rings on the downstroke through the scores or maybe more likely ridges on the scores stopped the rings seating properly?<br /><br />Bore not out of round and still stock 3" on telescopic bore gauge, + or - .001 error in good quality vernier. Don't have micrometer. Clymer says up to .004 OK. <br /><br />Only one score mark, running from exhaust port, looks like it might stay after a hone. <br /><br />Choices are:<br /><br />1. Rough as guts clean all cyls same way and ensure get all sanding grit out then reassemble with fresh gaskets and see if still blowing great clouds of unburnt fuel out, and if any improvement go to next choice. Wastes a set of gaskets but saves a lot of time on finding out if it's likely to work. I know theres a risk I'll leave grit in no matter how well I clean it, but I can live with it as the thing is currently dead anyway.<br /><br />2. Pull it down and hone cyls and clean out ring grooves and check tolerances and if all OK reassemble and see what happens (lot of work if no improvement) or fit new stock rings if required (cost of new pistons is what makes rebuilding with them uneconomic).<br /><br />3. Forget it and part it out.<br /><br />What do you reckon?
wayne h
Master Chief Petty Officer
Re: Do I need to bore cylinders or just hone?
i would tear it down get a good 3 stone hone and then a ball hone,try to clean the cylinders the best you can and go from there.i would not use sand paper you will never hold it the right way to get a fair sand all the way around the cylinder.if they look good after you hone them then rebuild it,if not part it out.eather way you will have to take it all apart to part it out.so why not see if you can clean them up.hones are cheap at napa.get a gasket kit and new rings,if it cleans up.thats the cheap way out.you might get lucky with it.i would try the new rings in each cylinder and see what 1ns fit the cylinders the best.u can clean everything up and not have to worry about grit in the cylinders
OBJ
Hi ya' Tink....<br /><br />My opinion....<br /><br />May be hard to do but....I don't think I would spend the time and money to get her going again. I believe I would look for a more up to date engine. It would pay in the long run. <br /><br />Just my opinion.
Sherman
I went the route of new rings, hone about 6 years ago. And although it didn't look perfect after the hone job it still runs really great. My engine is a 1979 Evinrude 115 hp.
