On my '93 Evinrude 175, I can run at full throttle for 20-30 minutes, then I get intermittent beeps and then a continuous warning alarm. Checked the therms, I am not overheating, but I noticed that the primer bulb had completely contracted and could not be squeezed. <br /><br />Is this normal, or should the primer bulb be hard at full throttle? The warning alarm may be correctly indicating a fuel flow restriction. <br /><br />Am I on the right track?<br /><br />Coincidentally (or not), the tach is malfunctioning as well.<br /><br />Thanks for any help.
