Re: older evinrude--no spark
Hey airmech....<br /><br />First, posting a year or model number would help us better help you with your problem.<br /><br />Replacing old coils with old coils just don't get it unless you know the coils are good. Get the new ones. A service manual will help also. In your case a generic like Seloc or Clymers would do fine. (check iboats store for manuals) <br /><br />At what gap did you set the points? Should be .020. With out seeing your engine, I'm going to guess that on the cam there is a place marked "SET". Put the points wiper here to set the gap. <br /><br />With the old new coils in place, did you set the air gap? This is the distance between the coils and flywheel magnet. Here's how to do it. Look at the posts the coils set on. At the top of each post you will see a small chamfered edge. The coils need to be aligned even with the edge of the chamfer for correct air gap.<br /><br />Don't forget to check the flywheel key. Make sure its in good shape. Torque the flywheel nut to 50-60lbs (if I remember right).<br /><br />Keep us posted as to your progress. Thanks.
