Re: Johnson 33 hp need info
Skeets thanks for the info...we must have the same motor....I have another question...Since there is no trim/tilt what do you use when you need to tilt up the motor. Mine has no bracket?? I have a motor totor when trailkering, but when you are ready to put in water the motor hits the ground so I need something in between. I have been using a pice of wood but its not a good choice...any ideas?
