  #1
Old August 5th, 2003, 01:32 PM
heyitswebb heyitswebb is offline
Default Does a 1972 evinrude 100hp O/B have a pee hole
I have a 1972 100hp starflite ser#0-27678 model #100293R . how do i know if teh water punp is working, does it have a pee hole? or is there a way to make one if there is not one? also looking for a web-site where I can veiw engine drawings till my seloc manual comes in. Thanks Tim
  #2
Old August 5th, 2003, 06:43 PM
Default Re: Does a 1972 evinrude 100hp O/B have a pee hole
need help before burning up motor
  #3
Old August 5th, 2003, 07:12 PM
alcan alcan is offline
No your motor does not have a tell-tale (pee-hole). It uses a heat sending unit that sends a signal to a light on the dash panal. How ever you should see water comming out the exhaust by-pass ports on the back of the leg. Your cooling system is also controled by t-stats. How do you tell if your motor is to hot with out a thermometer? Take a hand full of water and drizzle over the head/cylender area (both banks in your case). If the water sizzles and dries up fast it's too hot. If the water just sort of rolls around and steams a little it's ok. You obviously just got this motor. The very best way to know if your cooling system is working is to replace the pump empeller and inspect and service the rest.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1972 100hp evinrude selector switch shredx Johnson & Evinrude Outboards 3 October 29th, 2006 06:15 AM
1972 Evinrude V4 100hp Corbin Johnson & Evinrude Outboards 7 October 7th, 2003 08:30 PM
Power tilt for 1972 100HP Evinrude carlyboy3 Johnson & Evinrude Outboards 0 June 17th, 2003 04:43 AM
1972 Evinrude 100hp Ignition doodlebug Johnson & Evinrude Outboards 5 March 9th, 2003 05:40 AM
1972 Evinrude 100hp neutral problem doodlebug Johnson & Evinrude Outboards 9 March 8th, 2003 07:21 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
