I own a 1999 Johnson 115 that I had winterized at the local dealer last year. I was told it had stabilizer added to the fuel as part of being winterized. I've had the boat out four weekends and the engine continues to miss and will not run over 4,000 RPM. Thinking it was the carbs., I drained the carbs and added Sea Foam foam spray to the bowls. Didn't seem to help. Next time I took it out it missed for 10 miles, shut it off and then it ran great for 15 minutes @ 5,200 and then started to miss. Primer bulb seems soft but problem doesn't improve when pumping.
