Hello all. I have a 1972 Johnson 50HP hydro-electric shift. I finally got the shifting problems fixed, thanks for all your help. This thing would not idle, so I rebuilt the carbs(float,needle,gaskets,cleaned etc) I thought this would help. No change. I tried to adjust mixture screws. No change. I reset the ignition timing. No change. I replaced plugs (NGK). Now two outings later It has no power. I mean my trolling motor will go faster. It will only run at WOT and just barley moves the boat. When in neutral it seems to run okay(still no idle). Problem only when under a load. Fuel problem? Ignition probelm? Also checked fuel filter it was clean.<br /><br />Thanks
