those are part of the recirculation system.
the ones you are talking about on the crankcase are valves. the ones by the cylinder are free flowing. the is a tool to clean them out.
the screw in fittings have little screens that can get clogged with debree.
the book says
- to take a syringe with a clear hose, fill with isopropyl alcohol, connect to fitting.
fluid should not pass through the fitting. if it does replace.
-draw out the syringe, and air should pass through the fitting. if not replace.
the check valves also have to be checked
really need to get a manual.
the problem i found with the manuals is that the earlier versions dont get into the recirculation as well as the later.
a 1994 "ER" gives a good description on how to do it.
a 1991 "EI" and below only gives you what i just did.
now the 1988 "CC" manual doesnt even give you a recirculator hose diagram.
if it was me i would go to ebay & try get the the year you need and look for the "ER" manual as well for future reference.
just trying to help
