i ve removed my pump and motor, cleaned everything up , made sure the motor was in good working order. i noticed when id spin the pump with my hand that it seemed to have a drag in a certain spot,with this i noticed that fluid would come up out of the hole as if to refill the reservoir,so i fuigured that was natural. well when i put everything back togetherit got to where it would work fine. now a week into doing other things im back to the same tilt and trim problem.all connections are good. ive even ran jumpers and sometimes it will work and sometimes it wont, even with the jumpers. is this a result of the catch i noticed in the pump? is it a bad motor? <br /><br />also, ive tried to remove the two screws that are on top of the motor unit itself, to hopefully check the wire connections on the motor itself. they will not bug with out the possibilty of stripping or shearing the heads.<br /><br />any help would be deeply appreciated...i need to be on the lake!!!!
